Voltage reference 400mV 0.01% input 3v3
Picbuster
Joined Dec 2, 2013
1,062
I need a voltage reference 300/400 /500 or 600mV 0.01% low ripple.
Shunt system is generating noise and is therefor not useful.
Using voltage dividers are also source of noise.
Does one of you have experience with < 601 mV references and what type did you use.
Picbuster
RichardO
Joined May 4, 2013
2,270
I am not sure what you mean by this.
You say "Voltage reference 400mV 0.01% input 3v3" in your title. What does 0.01% refer to?
Linear Technology makes some 400mv references with a buffer amp -- the LT6650. I think TI, Maxim and other manufacturers might have some as well.
Picbuster
Joined Dec 2, 2013
1,062
Sorry to be not accurate : should read output 0.01% precision noise low as possible.
I need this to measure in nV.
I know all the techniques to reduce noise however avoiding as much as we can seems to me the first step.
Picbuster
Picbuster
Joined Dec 2, 2013
1,062
Shunt system is using a current source running into a resistor voltage over resistor is reference.
