Hi all, I am looking forward to build a simple test rig for following test.
Test: Disconnect the appliance from the supply mains at the instant of "voltage peak". One second after disconnection, the voltage between the pins of the plug is measured.
I have an Oscilloscope to analyze voltage however as you know since the supply mains freq is high 50Hz, we cannot determine exact voltage peak occurence time (for every 5ms which is small time). Is there any instantaneous voltage analyzer?. I need to prove that I have disconnected the appliance socket exactly at voltage peak?? May I please know how could I achieve it.
Any suggestions would be appreciable. Thank you.
