voltage operated relay
turbo1600
Joined Jan 12, 2016
7
hi, after a schematic that will turn on a relay at about 13.2 vdc and stay on , until voltage drops to about 12.8 then turn of .,
anyone help ?
mark k
30,808
For the average magnetic relay you would need to set up a comparitor circuit as the hysteresis of the average relay is way more than that.
#12
True. The last time I looked, an automotive relay was guaranteed to pull in at 80% of the label voltage and persist below 50%.
38,797
You could use two LM339 or LM393 comparators in a window comparator configuration to control a transistor driver that energizes the relay.
38,797
I like your circuit Mike.
It's a simple voltage comparator and has a stable-trip point basically independent of the supply voltage.
I think it meets Albert E's criteria. :)
