Voltage loss on LT3508 UVLO pin
Dukel192
Joined Feb 21, 2018
16
I designed a PCB with the LT3508 Step-down regulator. To enable the IC, a voltage exceeding 2.63[V] should be applied to the SHDN (UVLO) pin. Therefore I connected a voltage divider to this pin (36K6 and 21K resistor), which should give me 4[V] over the 21K when applying 11.1[V]. However when I connected the power supply I got 1.2[V] over the 21K resistor and on the SHDN pin (which doesn't exceed the 2.63[V] threshold)
The datasheet for the LT3508 can be found in the link below.
https://www.analog.com/media/en/technical-documentation/data-sheets/3508fd.pdf
Best regards,
ronsimpson
Joined Oct 7, 2019
4,771
It takes 6 to 10uA to pull the pin high. (at 2.7v)
If you think of 2.7V and 10uA that is like a resistor to ground. (you do the math) Now add that to your voltage divider.
Shut down pin can go as high as 40V.
You could use only a pull up resistor that will give you 20uA and no resistor to ground.
Dukel192
Joined Feb 21, 2018
16
Hi Ronsimpson,
I'm not sure what you mean with 2.7V and 10uA is like a resistor to ground and adding this to the voltage divider. I continued my search and removed both resistors. I connected the power supply via a 31k6 resistor to the pin. Now the voltage becomes 0.14V at the pin side. I don't know what to make of this. There seems to be no short circuits as far as I can see.
Dukel192
Joined Feb 21, 2018
16
Best regards,
Okay I'm stupid. The chip was upside soldered upside down
