Voltage limiter 9V and above
tattsiii
Joined Jun 21, 2023
Hi, I'm looking for a schematic to achieve the following:
If input voltage is below 9V then output 0V, if voltage is above 9V then output input voltage.
Max current - 4-5A
Max voltage - 14V
I tried using tl431 with irf5305, but can get it working.
Here is my schematic, it works on a test board, but when I solder it behaves weirdly. Sometimes voltage is negative, sometimes MOSFET is open on any voltage applied.
Could someone help with a nice schematic to achieve this?
Kind regards
LowQCab
Joined Nov 6, 2012
5,101
If You want exactly ~9-Volts, change R-1 to a 2,610-Ohms, 1% Resistor.
Then figure-out where your bad solder joint is.
