Voltage increase after rectifier issues
Mike Bedford
Joined Feb 10, 2015
18
I have a power supply design I am working on and I am using switching regulators by CUI (V7805-1000 AND the V7812-1000) instead of a typical linear regulator. So far, in testing, I am happy with these switching regulators. However, I am concerned about the longevity of my design and wanted to know if anybody has any suggestions.
Both of these regulators I am using now are rated to a max input voltage of 32VDC. I am feeding the regulators both with a 24VAC output transformer into a full wave bridge rectifier. Even though I should get 24VDC out of the rectifier, I actually get more voltage out. I am reading around 34VDC. This exceeds the regulator input by 2 volts. It seems to be working okay but I am not comfortable with this. In reading about full wave rectifiers it seems what I am seeing is normal as I need to factor in the peak voltage and should then be multiplying my rated 24VAC output by 1.4 which comes to 33.6V which is pretty much what I am seeing happen. I am a newbie to power supply design and this is more for a personal/hobby project.
I was not aware of this and was hoping to feed my regulators with 24VDC to be well under the 32 volt max input. I would like to look at quick and easy ways to bring this voltage back down to 24VDC. I hope to not have to add too many components or cost.
Any ideas?
Thank you!!
Mike
#12
How much current will you be using?
There are several ways to do this. Picking the right transformer is easily the most effective. You could use a regulator rated for more than 40 volts. Failing that, you need to get the peak voltage down below 32. I say don't take it down to 24 volts by just wasting heat.
34,809
AC voltages are RMS values, not peak amplitude.
To convert from RMS value to peak, multiply the RMS value by square root of 2, i.e. x 1.414
Edit: Just to make sure that you do not misquote me. This multiplication factor of 1.414 works a pure sine wave. The factor is different for other wave shapes.
To be sure, the RMS value of a constant DC voltage is the same as the DC voltage (i.e. conversion factor is 1.00).
18,104
And then subtract the diode drop for two rectifier diodes. Adding a few more diodes to drop as many volts as you want is an option.
There are also 27V zener diodes. I don't think you'd have to drain much current through the zener in order to keep the voltage down at 27V, but that's just a hunch. It depends on the properties of your transformer.
Alec_t
Joined Sep 17, 2013
15,118
If you have a 6VAC transformer of similar current-rating you could connect the secondaries of the two transformers in series, with appropriate phasing, to get 24-6 =18V and rectify that. Clunkier though (and perhaps not much cheaper) than just buying an 18V transformer :).
30,658
Mike
Maybe not quick or easy, but very cheap and effective is to remove a few turns off the secondary, you can usually reckon on an average of 2turns/volt.
Very much easier if the transformer is Toroidal type.
