Voltage gain of amplifier
ntetlow
Joined Jul 12, 2019
71
Hoping you can open the attached asc file. I would like to know why the voltage gain from V1 to RL (from 1 volt to 10 volts) can be calculated from the value of RF2 plus 1k (10k) divided by the RF1 value (1k).
38,624
Q1 and Q1 form a differential input with one input being the input signal and the other input being negative feedback from the output as determined by RF2 and RF1.
If we assume the amplifier open-loop gain is very high (the signal difference between the two differential inputs is then very small), then RF1 and RF2 provide attenuation in the negative feedback network that largely determines the amplifier gain , and the gain is as shown by ron.
LvW
Joined Jun 13, 2013
2,035
Unfortunately, the excerpt from the whole circuit (as prented by ronsimpson) does include neither V1 nor RL - nevertheles, my general comment is as follows:
You are asking " why the voltage gain from V1 to RL.... can be calculated from the value of RF2 ...divided by the RF1. "
This implies that the gain expression would be correct.
What is the source of this knowledge? Your own calculation or simulation or any textbook?
And - is the gain inverting or not?
The ratio of two resistors reminds me - of course - on opamps where the gain either is "-Ra/Rb" (inverting) or (1+Ra/Rb) which is non-invertig.
ntetlow
Joined Jul 12, 2019
71
The equation holds true for different values of the two resistances.. I cant unfortunately remember where I got it from but I agree it looks like the op amp equation you mention except that the value added to the numerator is 1k not 1.
LvW
Joined Jun 13, 2013
2,035
This is a sim of the non-inverting opamp circuit for the given amp feedback network, giving the calculated AC gain of 10:
However, the question remains: What is the relation to the circuit as given in post#1 ?
Is the circuit comparable to an ideal non-invering opamp-based amplifier?
BobTPH
Joined Jun 5, 2013
11,600
Think of it this way. The divider in the feedback loop is placing 1/10 of the output on the inverting input. The circuit is stable when the two inputs are at the same voltage. So the output must be 10 times the input.
12,222
Because that is the math of a non-inverting amplifier, which is derived from the math of a 2-resistor voltage divider.
https://en.wikipedia.org/wiki/Voltage_divider
https://en.wikipedia.org/wiki/Operational_amplifier#Negative-feedback_applications
https://en.wikipedia.org/wiki/Negative-feedback_amplifier
38,624
I think the open-loop gain of the posted audio amp circuit is high enough to give a reasonable approximation of the op amp circuit.
That differential stage with the current-mirror differential-to-single-ended conversion has high voltage gain.
LvW
Joined Jun 13, 2013
2,035
Yes - most probably.
My only problem is that I cannot identify any input or output signal which - normally - is reqired to say something about gain.
I never remember the formulae for op amp configurations. If you assume that they have very high open loop gain then any feedback arrangement will try to make the differential inputs have equal voltage. Typically it’s just a potential divider. Without feedback the output will swing to one rail or the other in a futile attempt to balance the inputs
ntetlow
Joined Jul 12, 2019
71
If you set RF2 to 1k, the same as RF1, the voltage output becomes 2k. The formula for the op amp (RF2 + 1)/RF! does not work, the formula (RF2 + 1k)/RF1 does, why is this?
LvW
Joined Jun 13, 2013
2,035
Really ? How do you know?
Again - how do you know? (It`s wrong).
As I have already pointed out in my post#5 - it is unusual and problematic to make a false claim and then ask why it is correct.
ntetlow
Joined Jul 12, 2019
71
Hust by the LTSPICE simulation
