Voltage for heater filaments...
Externet
Joined Nov 29, 2005
2,672
Hello
Exploring CRT circuits, found a couple of televisions that their filament heaters are powered with 4.3VAC. Checked with two voltmeters, showing same reading. I used to believe the filaments were 6.3V and vacuum tubes with other voltages showed it on the first two digits. Example 35W4 as 35 volt; 12AX7 as 12 volt. Am in doubt if picture tubes had their numbering starting with the filament voltage or the size.
Can anyone confirm the CRT numbering relation to heater voltage; and if the typical 6.3V was changed to 4.3V at some point ? Or 15KHz derived is playing something here ?
Papabravo
Joined Feb 24, 2006
22,111
Hello
Exploring CRT circuits, found a couple of televisions that their filament heaters are powered with 4.3VAC. Checked with two voltmeters, showing same reading. I used to believe the filaments were 6.3V and vacuum tubes with other voltages showed it on the first two digits. Example 35W4 as 35 volt; 12AX7 as 12 volt. Am in doubt if picture tubes had their numbering starting with the filament voltage.
There were all kinds of tubes with different filament voltages. Remember that these were often unregulated AC voltages straight from the secondary winding on the transformer. The 6 and the 12 series were common along with the tubes in the "All American Five" including the 50C5. The sum of the filament voltages was 120 VAC -- what a coincidence they were all wired in series.
38,752
TV tubes were designed to have their filaments operated in series from the mains, just as the "All American Five" radio.
The high power tubes (e.g. horizontal drive) had a high filament voltage rating, and the lower power tubes had a lower voltage rating.
The sum of the filament voltages added to 120V.
I think there may have been more than one series string for all the tubes in a TV.
DickCappels
Joined Aug 21, 2008
10,661
The 6.3 volt and 12 volt heater voltages were chosen for comparability with automotive electrical circuits of the day. Not many CRTs were designed with automobile electrical systems in mind, and only them from the late 1960’s, and they were not very common.
I can say that numbering for color tubes do not directly reflect the heater voltage.
4.3 VAC sounds odd but there is no reason to think it is incorrect.
Externet
Joined Nov 29, 2005
2,672
28,157
I disagree with crutchow about TVs with series string heaters. MOST of the decent quality sets did not do that, but quite a few of the "consumer junk" sets did use series strings, and a hot chassis as well. It did reduce the weight and eliminate the expensive power transformer. Also eliminated a bit of quality AND PRODUCT LIFETIME.
bassbindevil
Joined Jan 23, 2014
924
The basic reason for 6V and 12V filaments would have been to run them from batteries. 6V from 3 lead-acid cells or 4 dry cells. Radio was popular long before electric lighting reached every home.
