Voltage Follower with LM386
Cosmin Traicu
Joined Jan 6, 2017
12
Hi! I am triyng to make a voltage follower using LM386 ( i did conected the "Inverting input" to the output "Vout"), but the output doesn't look the same as the input. Even then input has 0V the output is about 500mV.
I would like to mention that "+INPUT" and "-INPUT" doesn't have the same potential.
Thanks for reading.
bertus
Joined Apr 5, 2008
23,013
The LM386 is a power amplifier.
You can not use it in the same way as an opamp.
Why do you want to use the LM386 as voltage follower?
There are some power opamps available if you need the higher output current.
Bertus
Cosmin Traicu
Joined Jan 6, 2017
12
Bertus
I tried to use LM386 because i had this one, but i will look for another one.
Thanks a lot.
Cosmin Traicu
Joined Jan 6, 2017
12
What is the signal you are trying to buffer (voltage, frequency)?
What is the load or downstream circuit you are driving?
ak
I am using a AD7390 ( DAC converter) to drive an MOS gate, but AD7390's output current is too low (1mA). SO i am trying to boost my DAC output current capabilities with an voltage follower.
