An op amp with a rail-to-rail output can slew its output vo;tage to equal the value of the supply rails. Normally, there is a diode drop or two in circuit, and an op amp's output voltage can only get to within a large fraction of a volt to the supply rail.
If your signal is a couple of volts and the supplies are +/-12 volts, this is not a big deal. However, if your supplies are +/-3 volts and your signal needs to be +/- 2.9 volts, having a rail-to-rail capability is quite significant.
Does it mean that the output voltage can go up to +/-11.9V if the supplies are +/-12V for this type of op amp rather than just +/- 11V for the other types?
I am doing an ECG circuit recently. I need to take into consideration of the baseline wander which will containminate my ecg signal when there is any body movement. It will shift up my ecg signals that is centered at the X-axis initially and this can result in saturation of the amplifier.
Can I use the feedback rail-to-rail op amp to deal with this problem? If yes, then how to do? Please help......
Getting an op amp with a couple of more volts output swing is not the best way to solve your circuit problems. I have no idea of what your ECG setup is built like, but your baseline shift makes me think your reference electrode is not doing its job.
