I have looked at forum history and although there's lots of transformer posts, I cannot find this answer.
I am a semi-retired tech guy and getting back into discrete circuits as a retirement hobby and I do not remember if I ran in to this in my past (I'm nearly 60 and have not played around with circuits since 1991).
My function generator putting out a sine wave at 30 khz on a very small (physically small) step-up transformer that shows a step-up on the secondary of 160:1 at the 30khz frequency.
The transformer is not in a circuit, I'm testing it standalone, at this stage I'm trying to re-learn all the stuff I haven't played with for nearly 30 years.
So at 1 volt peak to peak out of my function generator, sine wave at 30 khz, I see 160 volts p-p on my oscilloscope (I am using a x10 probe by the way so the scope actually reads 16 volts p-p).
I don't remember what would cause the secondary's output voltage to drop from 160 volts p-p to only 500 millivolts p-p as I increase the frequency to 1 Mhz.
The output voltage also drops off as I *decrease* the voltage from 30khz. Again there is nothing attached to this transformer except the function generator on the primary, and the oscilloscope on the output of the secondary, so I don't know why it would have a resonance at any particular frequency.
I remember the notion of hysteresis, ie. loss in the iron core due to heat -- is that why my output voltage keeps dropping as I increase the frequency from 30khz to 1 Mhz?
