Go online and google. (Voltage divider).And (voltage divider tutorials).
There's a ton of infromation how to use a voltage divider in a circuit.
They even tell you how to calculate for the input voltage R1 resistor
R2 resistor and output for output voltage.
This will get you started.They also have formula to calculate the divider.
The value would also depend upon the resistance to ground that Vout sees. If Vout is left open, it is one extreme. If Vout is connected directly to ground, it is the other extreme.
V5 is ratio R5/(R5+R6) of Vin. Period. Classic exam problem designed to make a student burn precious time if they don't see the concepts.
You DO have to assume Vout impedance is infinite, addressing Bill's point. But with that assumption, the confusing "loop" of resistors just loops around V5, and thus no current flows.
If you can't use the Vout assumption, then you need to express V5 based on Vout, recognizing that R3 and R4 are in parallel with R2, whereas R1 is in series with R2, the result of R1-4 are in parallel to R5, all in series to R6. Messy, but all just logical application of the rules.
