voltage divider bias
ect_09
Joined May 6, 2012
180
am confused about voltage divider Bias (figure is uploaded) that if i removed R2 resistance then transistor goes in saturation or cut off.
same with the R1, if i removed R1 resistance then transistor goes in saturation or cut off.???
while i remove both the resistor then what is the impact on the circuit.
Secondly, in some circuit i seen that most of the grounds are connected with resistor , i mean they are not grounded directly. they placed the resistor before ground..
kindly help me in this way..
Thank you....
ericgibbs
Joined Jan 29, 2010
21,641
R1 and R2 no longer act as current/voltage divider, so all the current flowing in R1 will enter the Base and the transistor will conduct heavily.
Without R1 there is in NO Base current so the transistor will not be conducting
Same as the last state, no conduction
The question is to vague to enable a meaningful answer.
:confused:
Thank you....
hi,
Could you explain why you are asking questions on how the transistor will be affected by removing components rather than asking their purpose.?:)
E
