voltage comparison switch
eetech00
Joined Jun 8, 2013
4,705
To clarify the situation:
As Tonyr1084 stated; this is a standard proximity sensor which I expected to output a signal when a ferrous material is close to the end of the sensor (closed state) and output no signal when the ferrous material is removed (open state)
What I am seeing with the sensor is:
VS = input voltage
VO = output voltage
When the sensor is in the Closed State VO= VS.
When the sensor is in the Open State VO= VS-2. I was expecting this to be VO=0
Those measurements indicate the sensor is damaged...
With PNP =on, output should =VS if open collector and no load.
With PNP = off, output should = ~mv, if open collector and no load.
eetech00
Joined Jun 8, 2013
4,705
This should work.
When metal is detected (within 8mm), output should be approx +12v
When no metal is detected, output should be ~mV.
James Hockney
Joined Oct 23, 2018
19
This should work.
Got it to work.
The signal Conditioner (for which there is no datasheet) that it connects into was pulling the Pin 4 Voltage up.
I ended up with a 330 Ohm resistor in the RL position which dropped Pin 4 to 0.3V when the sensor is OPEN and ~12V when CLOSED
Thanks for all the Help.
27,523
VS = input voltage
VO = output voltage
SORRY, but that is NOT a STANDARD proximity switch, unless you are using it incorrectly with no load current drawn. And based on the final results this was a correct evaluation. Open collector devices must ALWAYS have a proper load connected in order to function correctly.
