ElectricSpidey
- Joined Dec 2, 2017
- 3,350
According to that schematic you should also change from a 1/4 amp fuse to a 1/8 amp when running at 220.
Thanks Max, yes I believe it’s from the 80sLooks like what might be a slight miss-application of that transformer as it would appear it was originally intended for 110/220 with primaries either series or parallel.
Which is more commonly seen now.
Also must be an old unit as N.A. power is 120/240 for many years now.
Thanks Electric, the fuse inside the unit is rated at 1A250v.According to that schematic you should also change from a 1/4 amp fuse to a 1/8 amp when running at 220.
Well spotted Eletric, I will change the fuse and give it a try. CheersAccording to that schematic you should also change from a 1/4 amp fuse to a 1/8 amp when running at 220.
Thanks Tony, great advices.If a quarter amp fuse blew then an eighth amp fuse should blow even faster.
We all make mistakes. Are you adding the jumper and not removing the original or are you moving the original from one position to the other? The jumper should go to one OR the other setting. Not both. I don't know that you made that mistake or not - I just know it's the sort of thing I might have done. So don't do as I might have; do as I should have. And make sure there are no solder bridges.
Also, it's hard to tell, but I'm assuming the two black wires are the 220 primary of the transformer and the white is likely the center tap. I'm wondering if those three wires are correctly positioned on the board. If not - that may be the reason for the fuse blowing.
No worries Tony. I have to learn it the hard wayOK, STOP! With no connections NOTHING should be blowing up.
You removed the jumper. Pay close attention to the words I used - you removed the jumper. NOT "Moved" the jumper, "Removed" it. Sorry if it feels like I'm talking down to you - I'm definitely not. I just want to be sure I know exactly what you've done. If you've removed the jumper - according to the schematic no fuses should be blowing. NONE. So something is way way wrong here. Unless I'm missing something (not the first time for sure).
Completely remove the jumper. No fuse should blow. Incidentally, the schematic only shows a single fuse. If you're talking about a fuse on a power strip or something - then there's definitely something wrong and we need to get to the bottom of it. And don't be replacing fuses with higher values. ONLY use the correct fuse that belongs there. Higher rated fuses can cause fires.
The links are after the switch so with the switch off the links can make no difference.The unit was switched off when I plugged it to 240v but as soon as I inserted the plug into the socket I got the plug fuse to blowup.
MOV = Metal Oxide Varistor, which is a component that is supposed to change from a very high resistance value to a very much lower resistance value when the voltage across it exceeds some value. These are used for protection against excessive voltage spikes. On many occasions they do not return to the high resistance mode after a voltage pulse.Please forgive me I don’t understand what is MOV ! Yes it works fine with 110v
220V in the UK is a line and a neutral, while in the USA 220/230/240 volts is two live wires. The two systems are different.The links are after the switch so with the switch off the links can make no difference.
Now can somebody from US land explain the difference between the two voltages.
Is 110V a live and a neutral, whereas 220V is two lives?
In that case maybe there is a short between one power input and chassis earth and that should definitely be sorted out even it works OK.
So there is a short on the wiring between the power socket and switch which needs fixing.Any low impedance path to GND on a N.A. 240v supply will cause a high current, i,e. short circuit.
Both jurisdiction use a grounded neutral system so very little difference.
