I've read this. I have yet to get back into my old textbook on the subject of feedback, but I sure intend to do so soon. Since taking up my old hobby I feel like I'm always getting bumped back into that text. Believe it or not I used to be pretty good at this. When I took up electronics again I even had to read resistor codes from a chart. But it's coming back.An unbypassed emitter resistor for a common-emitter transistor is negative feedback.
Yes, and it increases stability. The distortion issue I brought up dictates high gain with a single stage if we're amplifying 10 mV to 10 V. On the other hand high gain creates stability problems, right? The circuit, if not built with proper methods might become an oscillator!It reduces the gain and reduces the distortion.
Yes, but I think the increase is not substantial -- from 10 mV peak bypassed to about 20 mV peak partially bypassed. I intend to experiment. I believe gain can be sacrificed for higher input voltage. Gain always gets sacrificed! What a martyr! LOL.The input can have a higher level.
I realize this. Thanks for your input!The voltage gain of a transistor is the value of the collector load to the total value of the internal and external emitter resistances.
