Hello all
It's seems like forever since I last popped up.
I am in the middle of building a new voice modulator. Those of you who remember me may well remember the last one I made. It's still working great and the members of the projectdalek forum enjoy the free 'how to build your own voice mod' manual.
I have moved on a touch with the design, thanks to Bertus pointing me at an interesting 'ring modulator' circuit.
It is based around the XR2206 IC and has only two other IC's and a handful of components to do it's job.
I have made some changes to the design. The simplest being the addition of a 10K resistor to take power to the input for electret mics. The second change was to changer the pair of LM741 IC's it used to a single LM358.
I'm glad to say the modulator part of the circuit works, as does the sound to light sub circuit, again Bertus had a guiding hand in fine tuning this, and the bridged TDA2003 amplifier.
My first prototype consisted of the modulation circuit and the sound to light circuit on a single PCB. The amplifier is a separate PCB. With them wired to the power supply and using a 10K Log pot to link the audio leads together.
This works very well indeed. Now the thing is it is possible to add an extra pot to the circuit to change the symmetry of the waveform. Also with a switch it is possible to change the waveform from Sine to Triangle. Both of these can have their symmetry changed by the pot previously mentioned.
The waveforms go from symmetrical to saw tooth in either direction. The crux of my question, if you haven't fallen asleep yet =D , is that the triangle wave, or just using the symmetry adjust engenders feedback.
I had this issue on my first voice mod which used a 7555/4066 IC combo to chop the audio. Bertus, yes it's that man again, showed me how to fit a 3 band equaliser between the audio out of the circuit and the in of the amplifier. This was a great success.
So I have made the same 3 band equaliser to go between the modulator and the amplifier. All these sub circuits are on the same PCB.
I had some initial problems with limited volume and the Bass trim pot cutting the audio off but solved this by removing the 100K resistor, marked red, as shown in the accompanying drawings. But the output at the speaker sounds a little 'muddy'?
If I miss the 3 band eq out and just link directly to the amplifier it sounds fine. So what am I missing with regards to the detrimental effect the eq seems to have.
Again, on the EQ image note the pair of 10uF caps highlighted in blue. The modulator has a 4u7 cap on it's output and the amplifier has a 4u7 cap on it's input so these have directly replaced the 10uF's on the EQ.
Here are the schematics for your convenience. Any help would be greatly appreciated.
EDIT: I have just changed the 4u7 caps for a pair of 10uF. Seems a lot better but still not quite 'clean'.
regards
Fenris
regards
Fenris
