Visio Professional on sale for $29.99 (88% off)
Status
Not open for further replies.
MrAl
Joined Jun 17, 2014
13,859
Only when I need to modify the schematic to make it understandable by non sim users.
I should mention that I do not like any schematic editors because they are so picky about where you place objects and how they connect. You have to constantly push things around sometimes to get it to look right. It takes significant effort.
When doing a hand drawing, unless it is a very complicated schematic, you can draw it up pretty quick even with lots of notes and component values and enumerations.
This led me to think about a program that can take a hand drawing and convert it into a nice, neat schematic, even if it has limitations for some things. This would be a monumental task though so I doubt I will attempt it, at least for now. I've done some other symbol recognition programs, but they involved fairly straight lines and rectangles and such so much easier. The software logic just has to follow the graphical lines to figure out what is what.
Maybe I'll give it some more thought, but it would probably take up too much time for me right now.
This isn't that funny but it seems comical just the same. I could see it now that the program would have to do things like: "Find something that looks like a resistor", "Find something that looks like a diode", "...something that looks like a transistor", etc., etc. (ha ha).
Probably also require 'training' like an ai program. I found that kind of thing way too boring to do for me.
KeithWalker
Joined Jul 10, 2017
3,625
etc..............................................
I feel the same way about schematic editors. That's why I'm still using Visio for schematics and circuit boards. It gives me the freedom to draw what I want, where I want it, and to re-scale any part or the whole thing. Over the years I have built up a library of basic electronic components. The version I am using is 32 bit. I copied it from twelve 3 1/2" floppies onto a CD and ran it in XP for many years. Recently I copied the whole file to a Win 8.1 computer and it runs in emulation mode.
atferrari
Joined Jan 6, 2004
5,031
Hola @MrAl
I vaguely recall an application able to do something like you propose, IIRC, based on .bmp ¿?
Not sure if one of those obscure (to me) components of Corel Draw. I do not discard that I could be dead wrong. Sorry if so.
Jon Chandler
Joined Jun 12, 2008
1,654
I purchased Eagle Pro Layout back in the day for what to me was a large sum of money. I needed the pro version not because I was doing anything complex but because I sometimes needed physically large boards.
The standard version of Eagle schematic capture would have been fine for my needs, but Eagle didn't allow that. Another large sum would have been required to purchase the pro version of Schematic capture.
I used TinyCad for schematics. Instead of generating a net list to import into Eagle to lay out a board, this required tediously adding all the footprints to Eagle one by one, and manually connecting all points by "air wires" before laying out traces. When the layout appeared complete, then I had to meticulously compare every connection on the schematic to every trace on the board. This served me well for many years, but it's a very slow process.
I tried Kicad at some point, but it was hopelessly confusing to me – from an Eagle user, that's saying a lot! I tried some of the sponsored offerings, but they all had shortcomings: your files were public, you could only have a small number of designs or you could only create a few library parts of your own.
Then I tried EasyEDA, pretty sure it wouldn't hold up to my beloved Eagle. There were some annoyances to start, like having to put every component and connection in a schematic and not being able to add parts directly to the board easily. *Shrug* Soldier forward and give it an honest try. And I've never looked back!
Draw a schematic, making sure to chose parts with the desired footprint. (EasyEDA's libraries are huge, so creating my own symbols and footprints are rare.) Verify all the connections in the schematic....
Now the magic compared to what I had been doing.
Click the button to "Create PCB" – no, this doesn't magically create your board for you as some newbies expect, sorry – but it does create a board outline of the space it thinks you need with all the footprints on the side and all the connections shown by thin blue "rubberband" lines. *The connections are already made according to the net list.*
Then you position components as you like and start drawing traces. Whoa there buddy – you can't cross traces on the same layer or connect points that aren't connected it the schematic. EasyEDA refuses to do that.
Then you run DRC and almost instantly you are warned of:
> Incomplete nets (missing connections)
> Clearance issues and connections that shouldn't be made. The software highlights the location on the board of each problem.
This eliminates the tedious connection by connection manual verification between schematic and board.
After "prettifying" the board (reference designators facing the same direction, nicely positioned by the component, labels, switches and connections identifies, etc), Gerber files that any fab can use are one click away.
I was blown away by how much this simplified my design process and sped it up. Plus, it eliminates little dumb errors. If you're designing boards of any complexity, (a program like) EasyEDA honestly does eliminate a lot of the tedious steps.
I'm not saying other methods aren't ok, but illustrating how much better the process could be than my Eagle+TinyCad approach of many years.
MrAl
Joined Jun 17, 2014
13,859
I took a quick look at your schematic (didn't check out the boards though) and I saw immediately that it was a very unusual design. The reason being that the op amp non inverting terminals are biased with two 10k resistors from a DC source, which is typical, but also that the two lower resistors (330 and 270) are also biased by the same two resistors.
This leads to an unusual interaction between the first and second stages. Since the ratio of the near 300 Ohm resistors and the two 10k resistors (5k in parallel) is very low, that means the near 300 Ohm value resistors have no problem modulating the bias junction between the two 10k resistors. Thus, the point of interaction is at the junction between the two 10k resistors.
Now lowering their values to 1k there would be much less interaction, and lowering them to 100 Ohms each there would be even less interaction. This would lead to a sharper response and a more typical operation.
Of course a sharp response is not always desirable, but broadbanding a bandpass filter usually isn't done that way. Each stage could be designed with a broader response to begin with.
There is also the possibility of battery operation, in which case two 10k resistors would draw less current than two 1k resistors.
What I would have to wonder about is what this is going to be used for, and was the broadband design done on purpose or by accident.
Also it looks like the center frequency is higher by close to 1kHz. Not sure if that was intentional or not either.
KeithWalker
Joined Jul 10, 2017
3,625
The circuit is part of a smoke detector system I built. The result of me attending many heavy metal rock concerts in the 80s and 90s have resulted in a serious loss of hearing for me for the last few years. Even when I am using my hearing aids, I can not hear anything above about 2.5KHz. That includes the 3.3KHz tone from our smoke detectors. It makes cooking much easier but presents some obvious problems. At night, when I am sleeping, I don't use my hearing aids.
I designed my smoke alarm to detect the 3.3KHz tone from the ceiling smoke detectors. This is amplified and connected to a Bluetooth audio transmitter. The output of a remote, paired Bluetooth receiver is detected and turns on a very loud, raucous audio tone which I am able to hear without my hearing aids.
In the diagram, I omitted the 10uF capacitors connected between ground and the positive and negative supply rails which I added to the circuit after the first test. The circuit works very well. The bandpass filter is narrow enough to eliminate other high frequency noises like running water, etc.
Each unit is powered by a 10V wallwart. A 9V battery in each is connected to the supply through a diode to keep the units running during a power failure.
MrAl
Joined Jun 17, 2014
13,859
I believe 10uf caps like that will make it much sharper so apparently that makes it work better.
I had a feeling that was the case :)
Status
dl324 Marketplace 4
Similar threads
Visio 2021 for $9.99
