Hi
Using a Vintage Vespa.
Does not have any signal lights.
Would like to start a small project by modifying Ampulla Bicycle Light turn signals.
https://www.amazon.com/Ampulla-Rechargeable-Bike-Tail-Light/dp/B06XXHDQLN
I plan to de-solder 1 bike signal LED each side & connect it to a bigger & brighter LED.
(Would be adding 2x LED for Rear, 2x LED for Front).
I guess it wont work as the current driving the small LED is too small to drive the bigger LED.
So i would need either a relay or transistor to accomplish this.
Which one should i go for & why?
Ampulla uses 3.7V rechargable battery
My Vintage Vespa runs 6V AC fed directly from a 6 pole flywheel magneto (nominal 6V),
does not have any batteries,
so i plan to use a power bank to charge the Ampulla & drive the new brighter signal lights at the moment.
In future i plan to run the whole circuit from the Vespa flywheel magneto.
Thanks
Thanks
