On the web, there is an assembly code simulator that has a simulated display.
I programmed a game for that simulator called “etch-a-sketch®”. The controls for
the game are the following Keyboard keys. Key 1 = left, key 2 = right, key 3 = up,
key 4 = down and Key 5 erases a pixel. I added a flashing red pixel to show you
where you are on the screen. Start the game by pressing key 1 or 2 or 3 or 4.
Copy and paste the code below to the inside of the blank second simulator screen. Click
on Assemble and then Run to play the game. The game works best on a PC.
The simulator can be found at https://skilldrick.github.io/easy6502/#registers
Code:
LDA #$6F
STA $40
LDA #$03
STA $41
LDY #$00
loop1:
LDA #$00
STA $00FF
LDX #$FF
loop:
DEX
BNE loop
LDA $FF
STA $0100
LDA $0100
CMP #$31
BNE loop2
JMP pointer
loop2:
CMP #$32
BNE loop3
JMP pointer1
loop3:
CMP #$33
BNE loop4
JMP pointer2
loop4:
CMP #$34
BNE loop5
JMP pointer3
loop5:
CMP #$35
BNE loop30
JMP pointer4
loop30:
JMP loop1
pointer:
LDA $40
CMP #$00
BNE loop10
JMP loop1
loop10:
CMP #$20
BNE loop11
JMP loop1
loop11:
CMP #$40
BNE loop12
JMP loop1
loop12:
CMP #$60
BNE loop13
JMP loop1
loop13:
CMP #$80
BNE loop14
JMP loop1
loop14:
CMP #$A0
BNE loop15
JMP loop1
loop15:
CMP #$C0
BNE loop16
JMP loop1
loop16:
CMP #$E0
BNE loop17
JMP loop1
loop17:
DEC $40
LDA #$0A
STA ($40),y
LDX #$FF
loop31:
DEX
BNE loop31
LDA #$01
STA ($40),y
JMP loop1
pointer1:
LDA $40
CMP #$1F
BNE loop18
JMP loop1
loop18:
CMP #$3F
BNE loop19
JMP loop1
loop19:
CMP #$5F
BNE loop20
JMP loop1
loop20:
CMP #$7F
BNE loop21
JMP loop1
loop21:
CMP #$9F
BNE loop22
JMP loop1
loop22:
CMP #$BF
BNE loop23
JMP loop1
loop23:
CMP #$DF
BNE loop24
JMP loop1
loop24:
CMP #$FF
BNE loop25
JMP loop1
loop25:
INC $40
LDA #$0A
STA ($40),y
LDX #$FF
loop32:
DEX
BNE loop32
LDA #$01
STA ($40),y
JMP loop1
pointer2:
LDX #$00
STX $43
LDA $40
SEC
SBC #$20
STA $40
LDA $41
SBC #$00
STA $41
LDA $40
CLC
ADC #$20
STA $40
LDA $40
SEC
SBC #$20
STA $40
LDA #$0A
STA ($40),y
LDX #$FF
loop33:
DEX
BNE loop33
LDA #$01
STA ($40),y
JMP loop1
pointer3:
LDX $43
CPX #$01
BNE loop8
JMP loop1
loop8:
LDA $40
CLC
ADC #$20
STA $40
LDA $41
ADC #$00
CMP #$06
STA $41
BNE loop6
LDX #$01
STX $43
JMP loop1
loop6:
LDA #$0A
STA ($40),y
LDX #$FF
loop34:
DEX
BNE loop34
LDA #$01
STA ($40),y
JMP loop1
pointer4:
LDA #$00
STA ($40),y
JMP loop1
