Vibration sensing with 3D magnetic sensor
nicoliJOY
Joined Oct 14, 2020
0
I saw the example about vibration monitoring with a 3D magnetic sensor - are there any specific examples available or evaluation boards?
Basically, I am interested in testing it out and not sure whether there is a specific software example or an easy way to have a test setup.
mhollfelder
Joined Oct 14, 2020
0
Hi nicoliJOY,
it depends on your concrete requirements and what you would like to test and implement.
We have Arduino software for a quick test and prototyping available on our GitHub repository, e.g. for the TLV493D-A1B6 here:
https://github.com/Infineon/TLV493D-A1B6-3DMagnetic-Sensor
You can combine it with a XMC2Go MCU board and start testing, more details can be found in the wiki as well:
https://github.com/Infineon/TLV493D-A1B6-3DMagnetic-Sensor/wiki
Also other 3D magnetic sensor variants are available, but for a quick test and setup, this might be a good point to start.
Please let me know whether you need additional information or are already thinking about a special setup.
Happy to provide you more information for starting your designs.
Thanks and best regards,
Manuel
