VGA Challenge
dannybeckett
Joined Dec 9, 2009
185
Hi guys.
I have a flatscreen monitor with a VGA output. The VGA cable, monitor side, is connected to the monitor via header on the monitor motherboard (no VGA socket. The other end of the cable has been snipped. I would like to buy a new vga cable and splice them together - but the colour of wires are not universal.
Is there any way, using a function generator, oscilloscope and multimeter, that I can find out what cable does what (so I know how to splice the new end on)? I know where 6 of the wires go - red analog, green analog, blue analog and their respective returns - they are easily identified by their colour (only bit which is universal) and the fact they have a ground sheath around them.
Heres a pinout for VGA
http://en.wikipedia.org/wiki/VGA_connector
Any help is massively appreciated
Dan
dannybeckett
Joined Dec 9, 2009
185
@ bertus - its a GNR F153. its pretty old. the circuitboard that the vga cable connects to is "LCT-M 94V-0"
@ rjenkins - nothing else is twisted or screened. I have attached pics so you can see the wires themselves. the 3 thick ones are the screened analog RGB cables. Im not sure which other ones are grounds
Thanks again guys
bertus
Joined Apr 5, 2008
22,922
I could only find a specsheet at the moment:
Max. Resolution
XGA 1024 x 768
Scan Frequency
Horizontal: 30kHz - 60kHz
Vertical: 50Hz - 75Hz
bertus
Joined Apr 5, 2008
22,922
Yes, the two frequencies come from the videocard.
In the old days with a CRT monitor those where the scanspeeds of the trace.
In LCD monitors the frequencies are used to derive to dot speed and the dot position.
bertus
Joined Apr 5, 2008
22,922
Do you have the rest of the cable?
(the piece that was cut off).
When you connect this to a video card you could measure the signals with an oscilloscope.
R!f@@
Joined Apr 2, 2009
10,004
Are u up to this. If so find some heat shrink sleeving that fit's those wires or some insulation tape and find a way to solder. I can guide you the connection with my eyes closed. Hopefully
dannybeckett
Joined Dec 9, 2009
185
Unfortunately bertus I dont have the rest of the cable - if i did i could use a multimeter to check and see what wire goes where =[
R!f@@ I am good with electronics, I can solder well. I have plenty of insulation tape. All I need to know is how I can find out the purpose of each wire coming from the monitor so I can splice a new end onto it. Ive checked the pinout of the genesis gmZAN2 chip and found vsync and hsync, but I cannot find continuity between those pins and any of the VGA wires which is odd.
