vfd drive repair help
canerland
Joined May 2, 2025
5
hello
We have a 20hp speed control. santronic g3 (yaskawa g series may be) It gave a Fu error. An n channel mosfet burned and the dc dc converter card capacitor exploded, we replaced them but we still continue to get the same error. The dc bus voltage returned to normal, around 580vdc. The user manual says the dc bus fuse is blown but there is no error there. I suspect the dc dc card. 580vdc ec enters and 320 vdc comes out, I don't know if it should be a different voltage.
Thanks in advance for your help. Which forum can I get help regarding driver repair?
28,225
OK, from the supplied circuit schematic it is clear that this is not a simple product. It may be that additional components on the various modules have also been damaged by the triac failure.
canerland
Joined May 2, 2025
5
Chopper card I applied 24 vdc to the card, it outputs a value like 23 vdc, it seems to be doing its job. When it goes above 320vdc, it seems to fix 320vdc..
