Verification of Hardware low pass filter circuit with simulation
viraj.dali
Joined Oct 20, 2016
36
Hallo
I have simulated the analog low pass filter in the LTSpice. Also after simulation is perform I have created a filter circuit on the breadboard. My question is how can I verify the output of breadboard circuitry with Simulation. Because simulation output is in Bode plot and breadboard output on oscilloscope is just the voltage against time.
Can someone please suggest me how can I verify it ???
Thank you in advance
Papabravo
Joined Feb 24, 2006
22,084
Sure. Here is what you do.
  1. Set the initial frequency and amplitude (Ain) of the input signal.
  2. Measure the output amplitude (Aout) and record the value.
  3. Change the input frequency
  4. Goto step 2 if input frequency is less than the maximum frequency of interest, else goto step 5
  5. For each data point compute 20*log(Aout/Ain) versus frequency and you have your result.
viraj.dali
Joined Oct 20, 2016
36
Thank you
Papabravo
Joined Feb 24, 2006
22,084
Hallo
Can you please suggest how can I verify the bode of phase vs Frequency ??
Thank you
Sure. On a dual trace scope you can superimpose the images at a frequency where there is zero phase shift. As you increase the input frequency you will see the phase shift. With delayed sweep you can zoom in to get a better view of the shift.
