vco high tuning at 100 MHz
oozy
Joined May 7, 2013
2
dear all,,
am really stucked with this assignment and really appreciate whoever can help me with the calculations.
We were asked to design a high tuning vco at the frequency of 100 Mhz.
with some help i've managed to design this circuit shown in the image, but still didnt understand the way of calculations and how to obtain the value for each of the resistors and capacitors.
Eventhough if any one can help with another design, i'll be so happy aas it'll help me to overcome this course
thanks
bertus
Joined Apr 5, 2008
23,006
It is clear that you made a mistake in copying the circuit:
(Thanks MikeML).
The control voltage is on the wrong side of the L1 coil in "your" schematic.
That way there is a wrong isolation between the tuning circuit and the tuning voltage.
oozy
Joined May 7, 2013
2
If you designed that, I'll eat my hat.
If you designed it, you should know the answers to these questions:
What purpose does R4 serve?
What purpose does C3 serve?
(Thanks MikeML).
thanks for ur rudness
am a computer specialized and have no good abilities with electronic stuff
i thought some one here is goin to help with pleasure not jst making fun of ppl
dont ever think if ur better than sum one in a single thing u can be superior.
yes i copied the circuit and did that modification by purpose mister!, the results are very accurate and an expert have just approved to me
you nerds:
i guess its better to celebrate ur christmas rather than making fun of ppl in an academic forum!!
35,180
Holy crap! Some guy copies a circuit as his own design and wants us to explain how to calculate the values.
Then he gets upset and calls us rude because we point out mistakes in his copy.
I hope your teacher finds out about this!
33,196
I do to.
Unfortunately, this is indicative of an increasingly common attitute of entitlement.
bertus
Joined Apr 5, 2008
23,006
I will take the part numbering of the original circuit.
C3 and C6 are 100 nF and NOT 104 pF as in your schematic.
C6 is to decouple the powersupply.
C3 is there to provide an RF ground for the transistor.
The 10 Ohms resistor R4 is to isolate the RF circuit from the powersupply and limit the current.
C5 is 3.3 nF to 4.7 nF and NOT 332 pF.
C3 will provide ground to the tuning circuit and decouple the tuning voltage.
L1 is the coil that determines the tuning frequency with C1, C4 C7 and D2.
