You are given with a battery source which is used to supply 6 electric bulbs.
At an instant only one should light ,others should be in off condition.... For a minute a bulb should lighten up at least 1200 times.....!
Name the circuit or setup which can be used to distribute the supply...!
Pls answer this guys
Welcome to AAC!
You have hijacked someone else's thread, which is disapproved of. The thread is also long dead! You are more likely to get a reply if you start your own thread.
Since this is clearly a Homework problem, YOU are expected to show your best effort at solving it if you want guidance. We don't do your homework for you.
