Variac AC/DC Power Supply.
PatrickSmith
Joined May 28, 2015
3
I need to create a variable output power supply that will give both AC and DC voltages up to 10Amp, to be used like a bench power supply for testing.
I have an idea of what i need but would like some help with the DC output.
What I have is:
240v 50Hz AC supply to the Variac through an isolation transformer.
The variac operates from 0 to 240v
Full-Wave bridge rectifier ( up to 400v) to convert to DC voltage.
I then need to smooth the output of the rectifier with capacitors, how would I calculate what capacitor I would require considering a possible maximum of 10Amp load and 240v AC input, but usually any load would be less than that, so 240v x 1.41 = 273vDC so to be safe a potential maximum of 300v DC.
Then after the capacitors a bleed resistor to discharge the capacitors as a safety precaution.
Can anyone suggest what capacitors and bleed resistor I require or if this design would work?
30,674
A capacitor size depends on what % ripple you are looking for, the % ripple is going to change with load, for simple general purpose anything over 1500μf should be OK.
30,674
The 10% value will change according to the final DC level out.;)
2.5v subsequent ripple at 250v is insignificant but 2.5 at 5v!!
MikeML
5,444
Very idealized, but it shows the ripple vs capacitance at 240Vrms input and a load current of 10A. The progression from bottom to top is 400uF, 800uF, 1600uF, 3200uF, and 6400uF.
Watch rectifier current rating, and ESR and ripple current rating of the capacitor.
