I am building a token dispensing machine for my home games room,
it's main component is a coin controls universal hopper, this is set up so that for each pulse on the input pin, it spits out 1 token, the hopper can take upto 5000 pulses in one go at 5ms appart, and does the counting out of the coins out it's self, so all i need to do is supply it with pulses to get coins out.. a push button repeatedly pressed can do this, but i want it automated.
What i want is a few buttons for 10, 25, 50 and 100 tokens out.
i was thinking a few LM555's would do the job, i dont need exactly the ammount of tokens requested out as it's just for home use,
so i thought, one 555 running in astable mode that does the pulses, i'd go for 10ms pulses, 10ms appart so i'm not right on the limit of the hoppers input of 5ms pulses.
Connected to the puls circuit would be 4 timer circuits, set to run the pulse circuit long enough to provide the requested number of pulses to the hopper.
So pressing the 10 token button triggers a 555 running in monostable mode, powering the astable 555 for 100ms,
the 25 token button triggers another 555 monostable, but that one runs for 250ms, and so on.
i have downloaded Yenka, and have been playing about trying to design what should be a simple circuit, but so far i am blowing the ic's up more than getting them to work.
i'd also need to ensure that none of the timers are triggered when first powered up as seems to be common from stray capacitance,
input voltage will be 12 vdc, output pulses need to be below 0.6 volts to be an off time, and over 2.4 volts to be an on time,
and the hopper is happy with 12 volt pulses on the input pin.
or if there's another way to do what i want using other components, but i have only basic tools... soldering iron, multimeter, pcb etching stuff, but nothing like a pic programmer or a clue how to use one... so i'd rather have a 200 component circuit that i can build than a 2 component one that i'd have to buy in equipment to make.
