Hi everyone,
I have looked everywhere on the forum for an answer but may well have missed it, sorry if it has already been asked.
I have a 240 volt water pump motor which has a max load of 370 watts. I have removed the water part and am just left with the motor. I've made a male thread on one end of the shaft to take a female coupling and this will hold the work I need the motor to do.
I need the motor to run at variable speeds from 0 to 3000 rpm, I've thought of a light dimmer switch but I don't think it would be good enough, my other option would be the speed controller from an electric drill. I am open to other suggestions and ideas.
Thanks in advance
B
Thanks in advance
B
