How can a variable resistor be used for the speed control of a DC shunt motor?
38,913
You generally need some control electronics to go with the variable resistor.
What is the voltage and current rating of the motor?
wayneh
Joined Sep 9, 2010
18,181
What you generally do NOT want to do is throttle the motor power through a pot. The pot would have to be rated to at least the power of the motor and that makes for an expensive pot. It can be done for small-ish motors (like a toy train set) but becomes impractical at larger scales.
MaxHeadRoom
Joined Jul 18, 2013
30,876
Not if its wound field, all you need to do is vary the relatively low field current.
Less current, higher RPM
JohnA12
Joined Mar 8, 2021
9
Vary the shunt voltage current is one simple way.
That is if wound field, not PM
I had another answer given to me which was adding the variable resistor in the field winding of the dc shunt motor and you can change the speed by varying the flux. Is this correct?
