This seemed like it should be so simple.
Changed transmissions in a 97 Ford Ranger, so there is no longer a Vehicle Speed Sensor on the transmission, as in the diagram. NOW trying to use the ABS sensor on the differential (red, on the diagram), which Ford also did, in '98, as the VSS. Both are variable reluctance, 2 wire sensors, but because they (diff and transmission) rotate at different speeds relative to each other, I put a Dakota Digital Signal Interface Unit between them, to adjust that.
Thought it would be as simple as attaching the red wires, as shown, but all I get from the speedometer, is a brief spike to 15mph or so when put truck in gear, then it stays at zero. After many hours and trying all kinds of ground permutations I finally cut the GY/B wire behind the speedo and attached the signal wire from the DD to the speedo. That works! BUT, I still need a corrected speed to the PCM and the Cruise Control, and maybe the GEM.
I guess it's possible there is a problem with the GEM or CC or PCM now, but they worked fine before the swap. Is this a ground problem of some kind?
Appreciate any thoughts you may have!
Thanks.
Thanks.
