Variable Power Source to Espe32 chip
__mr_harsh_patel
Joined Jul 14, 2024
9
Hello I have an power source say like solar panel with of output of 30 Volts . It should be fidin to the esp32 I/O pins . Now how can it be more safest way to do that other then the voltage divider. If the solar voltage goes beyond 30 Volts then what ? To add 3.3V zener diode to voltage divider or something else can work ?
ericgibbs
Joined Jan 29, 2010
21,448
hi mr,
What is the source resistance of the voltage driving the top of the 7k8?
E
Update:
The reason for asking, is that by using lower value resistors, the resistive load may pull down the Vsource voltage if the source resistance is high.
__mr_harsh_patel
Joined Jul 14, 2024
9
What's the source resistance means ? I have an solar panel output to voltage divider and zener diode in parallel which is fed in to controller chip.
ericgibbs
Joined Jan 29, 2010
21,448
hi mr,
As your voltage source is a solar panel, its output resistance will be low, so the 7k8 and 1K will not load the panel.
What is the measured voltage across the 3.3V Zener with those values?
E
__mr_harsh_patel
Joined Jul 14, 2024
9
While measuring the voltage through multimeter without connecting the chip it's readings is 30v input and 2.5V at the Output point of voltage divider with 3.3 V zener Diode connected. I am using 2 3.9K 1% Resistors in series and 1k 1% Resistor.
