Dr.killjoy
- Joined Apr 28, 2013
- 1,196
You are forgetting way to much and putting yourself in danger of hurting the car or yourself.. At 12v the battery is almost dead and the alt charges the battery at about 14.4v so you might want to check the math again..Ok do if you do the math with 50 amps and 12 volts the watts come out to 600 watts
With 50 amps and 14 volts it comes out to 700 watts. This should be ok correct? Either way the fuse is rated for 50 amps and i highly doubt the fans will draw that or it wouldn't be safe to be mass produced and sold in to the public correct? Please correct me if I am wrong.
Here check this out
https://bzerob2.wordpress.com/2011/11/15/ford-taurus-2-speed-fan-install/
