Variable cap Terminals- Help
28,262
Note that not only isthat lug with the elongated hole the rotor terminal, It is also common with some applications that will be OK, for the shaft and the mounting bushing. so if the capacitor is attached to a conductive panel, it will be electrically common with that panel. for others, it will not be OK. So you need to examine the application circuit first.
