variable band active bandpass filter
DaniKowa
Joined Sep 23, 2020
218
Hi guys! in these days I was evaluating the possibility of creating a variable band active bandpass filter with a working frequency from 5 to 10Mhz. It's possible to do it? I have seen that there are specific ICs for this but they have much higher working frequencies which are not for me. Thanks for your help!
LvW
Joined Jun 13, 2013
2,035
Of course, this is possible. However, there are still some questions:
* What about the filter-Q resp. bandwidth? No requirement ?
* In most cases (for most filter configurations) two parts must be tuned simultaneously. Is this allowed?
* How many opams ?
DaniKowa
Joined Sep 23, 2020
218
Hi @LvW , I try to answer within the limits of my knowledge. You need a Q that allows for a rather narrow band. Based on the graph that I am attaching, the ideal is to obtain a Q20 setting as a limit the use of a maximum of 5/6 opamps. Simultaneous tuning of several parts is allowed and this is an obstacle that I ran into but let me explain better. If it is a question of using potentiometers simultaneously, there are no particular problems. the problem arises when the variable components are capacitors and inductance and this is the reason why I discarded a passive filter preferring the active one.
So to answer your questions :
Q = 20
Max 5/6 opamps if needed
Ok for simultaneous tuning
DaniKowa
Joined Sep 23, 2020
218
It's preferable but non mandatory. It could be calculated in the center band (10Mhz). Then as you move it would tend to decrease I think. Quite right?
