Varactors for tuning HF oscillators
Chris - G0LOJ
Joined Jul 21, 2023
5
As part of an amateur radio project I'm trying to design a VFO with varactor tuning for the 80 m amateur band (3.5 - 3.8 MHz). I have a question which is perhaps very basic: In a common emitter Colpitts oscillator (for example) voltage swings comparable with the supply voltage occur across the tuned circuit. This is a little difficult if trying to tune the oscillator with a varactor which (to remain reasonably linear) needs to see small voltage swings - maybe of the order of a volt or less. Various practical ways round this can be dreamt up, but none of the published designs seems to take account of the problem. Am I missing something? Thanks, Chris.
BobTPH
Joined Jun 5, 2013
11,678
When using a varactor to fine tune, both sides of it are isolated from the tank circuit by series capacitors. There is no DC connection.
DickCappels
Joined Aug 21, 2008
10,661
The reason for the small voltage swing is to preserve the linearity of the waveform, particularly when the Varactors supplies most of the resinating capacitance.
What might help is to use the lowest power supply voltage to the oscillator, but if necessary apply a much higher tuning voltage.
Chris - G0LOJ
Joined Jul 21, 2023
5
The reason for the small voltage swing is to preserve the linearity of the waveform, particularly when the Varactors supplies most of the resonating capacitance.
Many thanks.
