Value Identification of a resistor in a circuit Diagram
Deltatango
Joined Apr 16, 2012
16
I am working on a power supply "freehand" no manual so am searching for value clues from the internet of similar designs and come across a reference I am unsure of:-
A resistor that is marked 2E along with other resistors ending with the "E" prefix if anyone can help me that would be great....
Many Thanks from David :)
Irving
Joined Jan 30, 2016
5,195
Good close up pictures would help.
Normally there would be 2digits + a letter so 02E would be 1.02Mohm (SMD Resistor marking), but 2E is unusual. Are you sure its a resistor and not some other device? It could be an SMD Fuse, 2E might be 2A slow blow. It could also be a zener diode.
Deltatango
Joined Apr 16, 2012
16
The marking I describe is Not on the device (which is a blown up smd about 8 to 1206 size) its on a circuit diagram, along with other similar resistor markings like 4.7E etc, my feeling and logic in respect of circuit positions is its R but I want to be sure.
Thank you so far
David :):)
Deltatango
Joined Apr 16, 2012
16
Yes I feel that it would be but I tend to be a bit dogged to find the answer to what E stands for, Epsilon or some other word??
Thank you for your help.
David
Deltatango
Joined Apr 16, 2012
16
To cover all bases I asked RS for a view on on this below is part of their response :-
Dear David.
Thank you for your recent enquiry.
For resistors E can be the same as Ω. It is often used in case of high power resistors (power not being less than 5W). Sometimes you can see R written instead of E.
We are however unable to determine the ohms or power rating of the required resistor form an E2 reference.
So from this I accept that "E" = "R" my only thought is who started it and why? one day may learn......
David
