Hi everyone,
I’m stuck on the same problem from few days. So I’m asking for your help…
The aim is to calculate the theorical irradiance distribution of a UV led on surface at a typical distance form this UV source.
(Unfortunately UV LED are not an isotropic source)
For example, let say:
- Radiant Flux Φe=20mW
- Viewing Angle θ1/2=60°
With the following radiation Characteristics
At a distance “d” from this source, how can I calculate the irradiance of a surface defined by the radius “r” ?
Then, with different radius, it gonna be easy to show the distribution, like the following on for example:
thank you !
thank you !
