I'm trying to use the ~0.1Hz output of one timer on a 556 to induce a slow-changing shift in frequency of the second timer at ~0.5Hz, by routing the output through R5 to the control pin of the 2nd timer and C3 in the attached. The timers are both working nicely on my breadboard.
I'd like to maximize the shift in frequency of the 2nd timer, up to a factor of two in either direction from the mean, ie. from 0.25Hz to 1Hz. With the current component values, I think I can see some variation but it's hard to tell and probably not a halving-doubling.
The math on this is a bit much and I'm hoping someone has experience with this approach or could simulate this for me. How much shift can I get, and how can I get this range to be stretched out to, say, 5 seconds of increasing frequencies followed by 5 seconds decreasing?
