Hi, I am wanting to use an optoisolator to drive a relay but need some help in how to generate the 2 power supplies needed.
I have 24Vac coming in and create a 5VDC and GND1 with an LM2596 that takes up quite a bit of board space with the external components.
So how could I create a separate +Vcc and GND2 for the other side of the optoisolator.
The GND1 is generated by the bridge rectifier that is rectifying the 24Vac. So if I used say a LM7805 to create a 2nd 5V signal, I would still not have a GND2.
Thanks.
Thanks.
