For my project I am plotting a Force vs Displacement graph using 2 analog inputs which are going to a DAQ.
The two analog inputs are coming from;
-A 5k potentiometer (for the displacement)
-A 1000 lb load cell sensor (for the force)
I would like to use a regulated 12V DC (1Amp) power supply for both the potentiometer and the load cell. I would like my graph to be accurate.
I am curious as to if the output values from one device will be affected if another device is using the same power supply.
Do I have to worry about this potential issue if I am using a "regulated" power supply?
Here is a link to the power source I am using ;
https://www.amazon.com/gp/product/B00K93AYTK/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Here is the datasheet for the load cell;
http://keli-cee.pl/dokumenty/134_DEFY-SS Datasheet.pdf
Thank you.
Thank you.
