Using Nodal Voltage Analysis when we have both a current- and a voltage source
Anders Imenes
Joined Sep 16, 2017
Hi!
The following circuit is given, and I am supposed to find the current I2 using the Nodal Analysis Method.
I've tried back and forth for a while. I defined x in the upper node, then I defined y in the lower node.The first thing I tried was to put the reference behind the Voltage Source, E. I also defined I1 as the current going through R1 from x to y (not on the figure).
I figured that for x
Ik = I1 + I2
This gave me the first equation
2A = ( (x - y)/R1 ) + ( (x - 30V) / R2 )
Then for y I get the same KCL
Ik = I1 + I2
This gave me the second equation
2A = ( (x - y) / R1) + ( y / (R4 + R3) )
X is supposed to be 31V, and Y is supposed to be -4V. Which is supposed to give me 250mA through R2. However I end up with totally different numbers.
Any ideas? Thanks for help!
WBahn
Joined Mar 31, 2012
33,326
Hi!
Ik = I1 + I2
Ik = I1 + I2
Look at your second equation:
Ik = I1 + I2
Ik is a current flowing OUT of node y, so you need to set that equal to the currents flowing INTO node y.
I1 = (x - y)/R2
is a current flowing INTO node y, so that's fine.
But what about
y / (R4 + R3)
that is a current flowing OUT of node y. More to the point, it is NOT equal to I2, it is equal to -I2.
MrAl
Joined Jun 17, 2014
13,870
Just to note in case it comes up, i had verified the quoted voltages of 31v, -4v, and the current 250ma in R2.
