Using FET for pass PWM signal form Source to Drain
hyyee
Joined Jul 4, 2023
5
Hello !
I need some help for circuit.
I designed circuit such below, but that is not general.
I'm curious about role of R4 resistor in this circuit.
The operation of circuit :
** R1 is pull-down resistor
case 1
@ PWM = high -> N ch mosfet : on
@ Input signal = High -> NPN Transistor ON -> P ch mosfet : on
=> OUTPUT = Ground (by N ch mosfet)
case 2
@ PWM = Low -> N ch mosfet : off
=> OUTPUT = Vdc * {R3/(R2+R3)}
case 3
@ Input signal = Low -> NPN Transistor off -> P ch mosfet : off
case 4
=> OUTPUT = Vdc
When I simulate the circuit in the image, it works as intended.
However, if i remove the R4 resistor, case3/4 behaves strangely.
And let me know if there's anything else I should consider in this circuit. :)
Irving
Joined Jan 30, 2016
5,155
Your circuit works, but not as you describe or intend.
Why do you need the NPN transistor AND the P-channel MOSFET to short the output to ground?
If R4 is null ohm = 0 ohm, then the P-Channel MOSFET is doing nothing useful.
If R2 is 0 ohm then you are shorting out your power supply, expect much magic smoke in the real world...
The simplicity of the simulation is lulling you into a false sense of security....
hyyee
Joined Jul 4, 2023
5
A MOSFET gate must never be left floating as it's voltage is then undefined.
Thank you for your response. What I'm wondering is why it's taking a peak (12V) and then dropping to 2V, can I understand it as a strange behavior caused by the gate being in floating state?
hyyee
Joined Jul 4, 2023
5
The resistors are not 0R, they are undetermined values. Sorry for the confusion.
