using an inductive amplifier to detect tones
Status
Not open for further replies.
Audioguru
Joined Dec 20, 2007
11,248
You might not need a filter is you use a shielded input cable.
Shielded cables are used to connect audio equipment together.
fred_uk
Joined Jan 3, 2009
67
hi,
if you follow this thread you will see iam building an inductive amplifier to amplify tones between 500hz and 3000hz, the circuit is now built but the tones aren't loud enough and there is abit of hiss in the background, any ideas how i could amplify these tones i want to listen to and reduce hiss in the background.
thakns
fred
hi,
iam building an inductive amplifier to amplify tones between 500hz and 3000hz, the circuit is now built but when tested (with headphones) the tones aren't loud enough, i can hear them just (if i use my pc speaker, which is a poor excuse for one, usb with abit of an amplifier) and there is abit of hiss in the background, any ideas how i could amplify these tones i want to listen to and reduce hiss in the background.
please note my electronics experiance is somewhat limited, it's been along time since i specified anything and iam operating on my limits :(
thanks
fred
this is what i had based the circuit on, i life the idea of using a filter too, where would i start?? i am trying to provide an output on detecting tones between 500hz and 3000hz
thanks for your replys
can anyone help me design a bandpass filter for my inductive amplifier,
i need to keep anything from 500hz to 3000hz and filter out everything else,
iam a bit of a beginner with my design knowledge being limited!! but i will be ok to build the circuit (hopefully!)
sorry if this appears a duplicated thread only i wanted the tittle to reflect the requirements of the project
thanks for your help
hgmjr
Joined Jan 28, 2005
9,027
I have merged all of your posts on the topic of inductive amplifier. In the future, please avoid the creation of new threads on the same topic.
hgmjr
hgmjr
Joined Jan 28, 2005
9,027
Yeah bill. In an attempt to consolidate the multitude of threads on the same topic by the same OP, I must have been in the midst of the merge when the reply was being made. I think I now have things sorted out.
hgmjr
Skeebopstop
Joined Jan 9, 2009
358
I've attached a nice active low pass filter differential amplifier circuit. It has -6dB per decade, not as great as some of the heavier duty active filters, but it wins points for amplifying and filtering at the same time.
R4 = R2
R3 = R1
Gain = R2/R1.
Bandwidth = 1/2*pi*R2*C2.
Just chain this up with another such circuit, where the first one is set to 500Hz and the next one 3000 Hz.
You can use the diff amps along the way for your amplification (if you need much power you'll have to buffer the output).
If you are driving a class A output stage and only have a +5V supply for the opamps, you can adjust the GND to be Vcc/2 and it will amplify around that as a midpoint.
Please note I just inserted some random op-amp in my schematic capture, so select an op-amp suited to your application.
fred_uk
Joined Jan 3, 2009
67
R4 = R2
R3 = R1
Gain = R2/R1.
thanks Skeebopstop, this is a great help, but....
how do i calculate the values and how do i fit this into my circuit?
sorry if i appear to be askin a bone question only it's been many years since i last dabbled in this area. thanks
Skeebopstop
Joined Jan 9, 2009
358
Sorry mate, I confused my statement.
You can only use this circuit as a low pass, so you will have to combine it with a 'high pass' if you want to create the band pass.
Here is how you could use the circuit I provided for gain and filtering
R4 = R2 = 10k
R3 = R1 = 1k
Gain = 10x
C1 = C2 = 5.3nF (3000Hz low pass).
So just throw the output of that circuit into a high pass filter of 300 Hz and you have your gain and bandpass in two op-amps.
fred_uk
Joined Jan 3, 2009
67
hi,
im going to build the filter that Skeebopstop has specified, however what chip should i use?
the current circuit is based on an LF351, should i use one of these? Other people have commented my inductive amplifier should be based on the lm386, but im not too sure if that will give me the full bandwidth required?
anyone got any ideas before i place and order?
Skeebopstop
Joined Jan 9, 2009
358
Depends on what you need of it. What is the range of your input signal? do you have a dual supply or single ended to power the opamp? Were you looking to only power a weak signal (i.e. headphones)? are you doing Class A, B, or AB type amplifier?
to implement easiest, Class A, use single ended 24v supply and bias a +-10V maximum output around 12V. At which point, if your application doesn't need to be horribly exact and only drives 30mA or so, just use the provided circuit.
fred_uk
Joined Jan 3, 2009
67
Im not really going to be using the headphones 'ouput' just want to provide a high output to power a small dc motor when tones beteen 500hz and 3000hz are present, the only power i have is from batteries, currently a pp3 9v battery
thanks
fred
Status
