geekoftheweek
- Joined Oct 6, 2013
- 1,429
I was more or less shooting in the dark. I have to say personally there's something else you're missing... the freaky led is just letting you know that. I once found when leds are in series and you put one in backwards although the string would not light up... there would still be enough current getting through the leds that my meter would pick up the proper voltage drop across the leds. Is your cathode of the led to ground? Is your ground for some reason being interrupted which would allow a minute backwards current through the green led and possibly mangle things up?
You might consider drawing some good schematics showing the entire circuit so others can see actually how you have it connected.
