Using 75ohm cable for antenna
wmodavis
Joined Oct 23, 2010
739
But it will likely work OK.
Try it.
Just be advised as cruts says there is some mismatch which can increase reflections and loss. If you have enough signal, some loss may be tolerable and reflections may not be severe enough to be noticeable.
Externet
Joined Nov 29, 2005
2,655
Is the receiver tuned for a single frequency as a two way radio or for a wide range of frequencies as a television ?
Or is it for transmitting ? Or both ?
vk6zgo
Joined Jul 21, 2012
677
A cable that short should never be spliced, just replace the whole thing.
Are you using the term "spliced" literally,or do you mean using a "bullet" adaptor between two coaxial fittings?
If the former-No you shouldn't do it!
If the latter,proper coax adaptors contribute very little to losses,& in themselves,cause hardly any discernible mismatch.
To the OP--try it!
The mismatch between 50Ω & 75Ω is quite small.
If it causes a problem,you will have to get a 50Ω extension.
gerty
Joined Aug 30, 2007
1,305
To the OP--try it!
The total cable length is going to be less than 6'.There's no reason to splice something that short. The cost of the proper connectors/coupling would be more than the the cost of the cable. Plus, a splice always introduces a weak point into the cable. And looks totally unprofessional.
vk6zgo
Joined Jul 21, 2012
677
Out in the real world inline connections are often used to go from fairly inflexible cable to flexible coax "tails" of similar length to that proposed.
Cost?------- The OP may already have the adaptors & the short piece of cable..
I have seen this term "spliced" used a lot recently for cables which were properly joined with an adaptor.
In around 40years in TV & Radio Broadcasting I have never ran across this usage amongst people who (like myself) worked with coax cables.
I have seen coax cables that some newbie or lazy person really has spliced,& they are a mess!
tracecom
Joined Apr 16, 2010
3,944
By the time the OP makes up a 1 foot piece of cable with connectors on both ends, he/she could have made a 6 foot piece of cable with connectors on both ends, and avoided the "splice" altogether.
electronewb
Joined Apr 24, 2012
260
I have some TNC connectors but I need the female adapter but I could go TNC to BNC to TNC but I think that would create a major loss
vk6zgo
Joined Jul 21, 2012
677
I assumed that you had the correct connectors available.
You can probably get TNC adaptors,but if you can't,it is getting a bit messy mechanically, so now, I agree with gerty & tracecom.
You may as well replace the whole cable!
By the way,you never told us what the application & operating frequency were.
