Uses for a 0 to 9 Counter?
Musical
Joined Sep 10, 2017
Having recently watched one of Fran Blanche's youtube videos I thought it would be fun to put together my own 0 to 9 counter.
Luckily, I had enough parts around including some old IC chips. The circuit is pretty straightforward:
555 timer at about 1 Hz -> SN74LS90N 0 - 9 counter -> SN74LFS48N -> CC 7 segment LED
with some LEDs: one on the clock line and one on each of the BCD lines.
While the blinking LEDS are pretty and seeing the numbers 0 - 9 is neat, it lead to a question for me:
What are the uses for this circuit as a piece of test equipment?
LesJones
Joined Jan 8, 2017
4,511
I single digit is not much use but you can cascade a number of counter stages to display as many digits as you want. You could then count items going past on a conveyor belt for example. There are many more things you could use it for.
Les.
digsys
Joined Jun 27, 2018
27
Connect a sensor to the 555 - eg Sound, light, wind etc and have it affect the 1Hz .. so the scan rate will reflect the intensity of the sensor.
Musical
Joined Sep 10, 2017
Frequency or period counter or digital voltmeter (single slope easy).
I appreciate the replies and as a result started to discover some (new to me) things. A single slope digital voltmeter has peaked my interest - is there a book which you might suggest for further reading?
danadak
Joined Mar 10, 2018
4,057
If you google "single slope a/d" you will find several ap notes
on web discussing this architecture on web.
Regards, Dana.
