used capacitors from ebay
BR-549
Joined Sep 22, 2013
4,931
I would guess that they are fine. But that's only a guess.
They have been used......and priced as such. I would bet they're still in spec. But I am a terrible gambler.
dendad
Joined Feb 20, 2016
4,637
I would think they will last "forever" unless damaged. It will be pretty easy to test.
Measure the capacitance and if you have a high voltage Megga, run them up to 10KV or so to check for leakage.
A quick search could not locate any new parts of that type number but no doubt they are available somewhere. Bu the Ebay second hand caps should be ok I reckon.
oz93666
Joined Sep 7, 2010
742
2500pf 20KV !!! This is the sort of capacitor you can build yourself for a fraction of the price ..
Wax paper and aluminium foil ....Wax paper breaks down at 40Kv /mm so 1mm thick is ample (polythene is also good )
2500pf is so small you wouldn't need much of an area for the 'plates'.... Anyone know how much???
EDIT ... here we are ....
e = 17.5 x 10 minus 12 ..............C = 2500 x 10 minus 12
2500 = 17.5 x A/ d ................. d = 1 mm ....
So 2.5/17.5 = A ............. Area of plates is around 0.14 of a square meter ... very easy to make .
