Use of different power supply of microcontroller
loganjon
Joined Sep 1, 2017
21
i have to connect a pressure sensor to 3.1v and a shift register to the 5v. Of a teensy 3.2. in the same circuit.
Can I do it directly, or do I need a level converter. I would not prefer to use a level converter.
Thank you.
DickCappels
Joined Aug 21, 2008
10,661
If these are digital signals for use with CMOS you would get most likely get unreliable operation without a level shifter. You can tell for sure by checking the gauranteed minimum high and maximum low input levels of the teensy 3.2 against the gauranteed maximum high and maximum low output levels of the pressure sensor.
35,268
Details, details, details.
What is the part number of the pressure sensor and shift register?
How are your components connected?
A circuit diagram would help.
loganjon
Joined Sep 1, 2017
21
I am sorry.
I use seven CD 4021b shift register in a daisy chain with hall effect sensor to digitalize an accordion. And a
BMP180 barometric pressure to measure the air there for. The BMP 180, I bought is a china product. Unfortunately without datasheet. My question gose only to power supplying the shift register and BMP 180 from the Teensy. Teensy has both 5v and 3.3v.
I will try to post later a circuit diagram when I get home
loganjon
Joined Sep 1, 2017
21
Sorry I can not understand why do I need the level shifter. I would power each of them with the required power. I expect it should work fine. Or do I think wrong?
AlbertHall
Joined Jun 4, 2014
12,655
The I2C from the teensy will be 5V but the BMP180 I2C will be 3.3V. The 5V may damage the BMP180 and/or the 3.3V will not correctly connect to the teensy.
