Hi, I started a home project of converting a Xbox into a retro game console. It's the first time I've done anything like this so learning as I go, the power supply to the raspberry pi 4 I have has a USB type C connection. I want to be able to strip a type C apart and wire it into a board which controls voltage and current. The reason I'm doing like this is I want to keep everything else the same in terms of power supply, then have everything housed inside the Xbox casing. Presumably all I need to do is trace the supply and ground wires to the cable and this should work? Or is there more to it than this? I don't seem to be able to find anything online that helps so just wondering if anyone on here may know.
Thanks in advance
Thanks in advance
